how to install cadence ic5 on ubuntu 6.10
bruteforce
Newbie level 1
Newbie level 1
I tried to install cadence ic5 on ubuntu 6.1 and followed instructions in this thread: .
The problem is that after I run "softload", I got following errors:
sort: Warning: "+number" syntax is deprecated, please use "-k number"
Checking data files...
Executing control programs (pre-load) ...
load_pkgs: 691: ./install/pkgs/cdsFileManager01.04-s011.exe: not found
SL-10:Installation of cdsFileManager01.04-s011 declined by control program (PRE_LOAD)
cdsFileManager01.04-s011 will not be installedload_pkgs: 691: ./install/pkgs/cdsFileManager01.04-s011.exe: not found
It would be so appreciated if anyone can help.
Use ubuntu 5.1
incompatability of the application and the OS, change OS may help
IC5 is design to work with RHEL 2.1
