How to install Cadence IC5.0.33 under FC2 [Help me!]
lile
Newbie level 2
Newbie level 2
How to install Cadence IC5.0.33 under FC2?
1.Incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed.
2.error: /EDA/cadence/ic533/tools/lib/libvirtuos_sh.so: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
ic 5.0.33 is not run on fc2
u must install all package from fc2 (kernel dev ,software devleop, ), i think new kernel version is not support by candence ic5
try to work in red 7 an 8
see this post
Use RH7.3 or RH8.0 to install your IC5.033
Before to run icfb &, you need to enter:
export LD_ASSUME_KERNEL=2.4.1
