how to install a program that's in bin file format on Linux?
ahmad_abdulghany
San Jose, California, USA
Hello all,
I usually when get a program, get it in .rpm format, and just source it from shell to install, that's fine. Then, how can I install a program that i have other formats for it, say for my current case .bin file?
Thanks alot in advance,
Ahmad,
You can use file command to detect the file type:
file your_file.bin
If it reports the file is a ELF format, you can run it:
./your_file.bin
Re: how to install a program that's in bin file format on Li
thank you Hughes,
but it needed to change its mode first to be execuable, by using a command like chmod +x <file_name> then sourcing it as you mentioned opened it ..
Regards,
Ahmad,
If it is a cd file, you need nero to burn it using CDROM.
If it is a CD image, then you may also need the associated CUE file, because it sometimes contains special CD burning parameters.
The BIN/CUE format was originally created by GoldenHawk for CDRWIN.
If it is a CD image, you can convert it to ISO image and mount the ISO image with "-o loop" option. There is no need to burn the image.
