How to insert analog blocks in Verilog-A in ADS?
tromeros
Member level 1
Member level 1
ads verilog
I want to insert some analog blocks written in Verilog-a code in ADS2004A. I have done this in Cadence but in ADS there should be a different process.
My question so, is how to insert the blocks. There is a folder named "veriloga" where the veriloga files are stored but then i don't know what to do.
I would be thankfull for any information.
ads veriloga
If you are using SPICE based simulator, you can use .verilog <filename> in the SPICE file deck. The same is the case with Spectre based simulator.
