chasekan@gmail.com
Member level 1
#include <htc.h>
rom unsigned char mydata[]="hello";
void main(void)
// Write your code here
unsigned char z;
TRISB =0;
for(z=0;z<5;z++)
PORTB=mydata[z];
while (1);
hi i am using hi tech c compiler,to store the data in the program code space, here i ve used rom keyword, is the way correct or i ve to use any other notation....it shows the below error msg....if possible suggest me some material for to get knowledge in PIC controller using Hi tech c compiler.
HTML:
Warning at file ../main.c line 9 column 5: (374) missing basic type; int assumed
Error at file ../main.c line 9 column 5: (314) ";" expected
make: *** [main.p1] Error 1
