samz kazi
Newbie level 6
- Joined
- Feb 26, 2013
- Messages
- 12
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,405
Coding for receive, reading, parsing and act based on SMS command is little bit complicated. If you use LCD Module and Keyboard then it is fine. You can directly store the required phone numbers. But, if you don't use Keyboard, you must code for the sequence that I mentioned. Let me know whether you use LCD and Key Board. NOTE: But, still you need to code as per my sequence in order to run/off motors based on SMS Command (NOT from Ring Tone, it is quite simple compared to SMS Command).
No..i am not using any keyboard or lcd...my idea is little different...when sensor 1(water level) is 1(sufficent water then the motor will on and all other funtctions will be carried out...but if sensor 1 is 0 then there is no water in tank..so this alert shoud be given to the user through message using GSM SIM300 module.....i just want to send a message,,,no receiving or controlling part is there/////
