truffaldino
Junior Member level 3
How to indicate overflow of 4017 counter? How to stop counter?
Is it possible to force 4017 to set some "flag" indicating the overflow afrer just one full cycle: E.G. to turn an indicator LED on afrer one full cycle and then keep this LED switched on permanently. The "carry" pin of the 4017 is high only half of the full cycle, so one needs to use some trick.
I need this to count number of pulses from a circuit consisting of two 555 (First 555 is set periodic. It is modulated by the second one-shot 555), just to know if the pulses were counted properly without an overflow.
