How to increment my variable value in fastly ?
karthikarun
Newbie level 2
Newbie level 2
maximum value = 1000.
int i;
if(condition_1==true)
//variable i should get increment by 1.
else if(condition_2==true)
//variable i should reach the maximum value 1000 faster . How to write logic for this???
thanks for advance help.
int i;
[COLOR=#FF0000]i++; // this adds 1 to the value of i[/COLOR]
[COLOR=#ff0000]i += increment;   //increment is the amount you want it to increase by each time[/COLOR]
Set 'increment' to a value before using it or else put the actual value in the line. If the maximum is 1000 and you want it to reach that 1000 times faster you only have one step of increase, you could change the second red line to ' i = 1000'.
Brian.
Supposing you want to use it in a limited keys keyboard routine, you could use something like that (auto adjustable increment):
        //maximum value = 1000.
        //int i;
        static unsigned char speed = 1;
                  speed = 1;
                  i++;
        } else if(condition_2==true)
                  if(speed<20)
                              speed++;
                  i+=speed;
        if(i>1000)
                  i = 1000;
Thanks a lot betwixt, xenos for your valued reply.
I'm tried xenos code. its work well.
