How to increase the volts from source DC (PC source)?
ibstk
Newbie level 3
Newbie level 3
how do you increase the volts
Re: increase volts source DC
If it is a switching regulator you probably can adjust some resistor ratios to do this. Watch out for the possibility of the voltage across different components being larger enough to exceed their rated maximum values.
You can also follow the supply with a switching regulator which has the output voltage you require.
