wholx
Member level 4
can someone explain how a source degeneration config works for increasing the SR?
if the circuit is composed of a differential pair followed by a common source amp then an output stage. a compensation capa is applied by connecting the Gate and Drain of the CS transistor. so the SR could be calculated as
SR = Vdsat(diff)*Wp2
where Wp2 is the sencond pole of the circuit.
in this case, how to use the source degeneration in the differential pair to increase the SR?
