thannara123
Advanced Member level 5
- Joined
- Jan 7, 2010
- Messages
- 1,602
- Helped
- 122
- Reputation
- 244
- Reaction score
- 116
- Trophy points
- 1,353
- Activity points
- 10,626
How to increase FM radio signal ? ,
any antenna booster circuits design ?
what is mean by Low Noise Amplifier (is it called antena signal booster like tv Booster ) ?
any circuit reference ?
thanks in advance
i would use either the Dual gate MOSFET, or a transistor
connected in common base, and an rf choke at the collector
the input is then applied to the emitter, you can then use an
emitter follower to match the output impedance.
or just buy a MINI-CIRCUIT RF AMP MAR6 say and use that.
i have simulated a circuit that you may try using multisim
simulation software. the gain is about 10DB
thanks in advance
