ajaykumar988
Member level 5
how to amplify parallel port current
The port gives off eough voltage (the relay is rated at 5v, port output pins give of 5.something). The relay does not work; i dont think there is eough current.
Is it possible for me to tie multiple output pins together in some way to make the current higher while maintaining the same voltage level?
Would the parallel port itself have some sort of diode on the output pins so that electricity doesnt flow back into the circuit?
