turuk
Junior Member level 3
Ive designed a printed yagi with the MSC to CPS balun. I put the images of antenna and sparameter result. I want to pull down the band around 1-2 GHz to (-10) dB also. The problem is no matter which part of the antenna configuration ive changed, it always affects the band around 3GHz. The substrate lenght is 50x65mm. Any help will be appreciated.
