neocw said:How can I improve the bandwidth for a square fix antenna? Will it help if I use a perforated ground plane (etched hole) instead of a solid ground plane?
Resonant freq is at 2.45GHz, permittivity at 2.45.
vagee said:I have some experinece on bandwidth enhancement of microstrip fed patches.One way to incereace bandwidth is by adding paracitic patches on the left and the right of the patch!Please find a paper attached.This paper refers to a PIFA antenna but the idea is the same.Sorry but i couldn't find something more close to microstrip bandwidth enhancement.
Another way that i have personaly used for a patch antenna is the one shown in paper "harmonic control of a square microstrip antenna operated at the 1.8 Ghz band". There you can see in figure 1 that the microstrip feed is "inserted" into the patch.Try to make it like that and you will definately get better impedance matching thus your bandwidth will broaden. Let me conclude with a more exotic solution that is presented to paper with Frequency Selective Surfaces...you will see that by addind a pattern of parasitic patches around the patch you get very nice results.
Hope I helped
Dear Vanqee,
Can u upload the "BW enlargement.rar" once again ?
Thanks!
vagee
