How to inclucde .vec file in the process of nanosim?
beckwang
Newbie level 3
Newbie level 3
nanosim
Re: nanosim
Do you have any documentation about VTRAN?
nanosim
The syntax about .vec using in nanosim is the same as it in the hspice.
Re: nanosim
Would you explain what nanosim can do in IC design?
Re: nanosim
I think Nanosim is a quite good simulator for the circuits which takes HSPICE long time, such as PLL, memory... And its precision also can be accepted.
nanosim
use " -nvec filename.vec"
nanosim
At first, thanks for your reply,
of cource, -nvec filename.vec is a way to include vec file , but i want to know how to include the file such as:(is=vec)(en=element.vec)(ot=pa0,pa1,pa2)
thank you very much!
nanosim
I have called the service person of SYNOPSYS, he told me that the previous usage was cancelled, now it can only use the -nvec in the command to realize inlcluding .vec file.
