hrkhari
Full Member level 4
Hi Guys:
The phase noise of the designed pMOS based LC-VCO, 4-3GHz of tunability, was indicated to be -126dBc/Hz at 1MHz of offset frequency, when I integrated an open drain buffer the phase noise degraded to about -67dBc/Hz. When it is indicated on the phase noise of a VCO in many journals , it is around -112dBc/Hz, does this value correponds to the phase noise of an integrated buffer or standalone phase noise of the VCO?. How do I improve my phase noise performance of the integrated VCO and buffer?.Thanks in advance
Rgds
Rgds
