uoficowboy
Full Member level 3
- Joined
- Apr 4, 2009
- Messages
- 169
- Helped
- 6
- Reputation
- 12
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Seattle, Wa, USA
- Activity points
- 2,964
Hi - I'm trying to build a discrete low side FET driver. My plan is to use it to drive a FET as part of a fairly fast DC/DC boost converter (probably switching at 250KHz). Thus I'm looking to minimize rise and fall times on the gate of the FET.
Please see the attached LTSpice schematic and simulation results. I'm seeing around 70ns rise and fall times. Not horrendous, but not awesome either. The diode is there to keep the BJT from saturating. I tried diodes in the same place on the other two BJTs but it did not seem to help much if at all. The one diode I have on there doesn't seem to make that big a difference, either.
I've also included the spice files that you need to run the simulation.
Can anybody suggest a means of improving the rise and fall time of this circuit?
Thanks so much!
Thanks so much!
