1.0000k hz 0. db at 39.2943u Deg ****Fundamental****
2.0000k hz -69.0041 db at 407.0327m Deg Harmonic # 2
3.0000k hz -81.8473 db at 838.3165m Deg Harmonic # 3
4.0000k hz -88.4335 db at 1.2383 Deg Harmonic # 4
5.0000k hz -92.9984 db at 1.6213 Deg Harmonic # 5
6.0000k hz -96.5294 db at 1.9946 Deg Harmonic # 6
7.0000k hz -99.4235 db at 2.3620 Deg Harmonic # 7
8.0000k hz -101.8827 db at 2.7256 Deg Harmonic # 8
9.0000k hz -104.0242 db at 3.0866 Deg Harmonic # 9
10.0000k hz -105.9228 db at 3.4458 Deg Harmonic # 10
11.0000k hz -107.6293 db at 3.8036 Deg Harmonic # 11
12.0000k hz -109.1798 db at 4.1604 Deg Harmonic # 12
13.0000k hz -110.6009 db at 4.5164 Deg Harmonic # 13
14.0000k hz -111.9130 db at 4.8718 Deg Harmonic # 14
15.0000k hz -113.1318 db at 5.2267 Deg Harmonic # 15
16.0000k hz -114.2699 db at 5.5811 Deg Harmonic # 16
17.0000k hz -115.3376 db at 5.9352 Deg Harmonic # 17
18.0000k hz -116.3430 db at 6.2891 Deg Harmonic # 18
19.0000k hz -117.2933 db at 6.6427 Deg Harmonic # 19
20.0000k hz -118.1941 db at 6.9961 Deg Harmonic # 20
21.0000k hz -119.0506 db at 7.3493 Deg Harmonic # 21
22.0000k hz -119.8668 db at 7.7024 Deg Harmonic # 22
23.0000k hz -120.6465 db at 8.0553 Deg Harmonic # 23
24.0000k hz -121.3928 db at 8.4081 Deg Harmonic # 24
25.0000k hz -122.1085 db at 8.7609 Deg Harmonic # 25
26.0000k hz -122.7961 db at 9.1135 Deg Harmonic # 26
27.0000k hz -123.4577 db at 9.4661 Deg Harmonic # 27
28.0000k hz -124.0953 db at 9.8185 Deg Harmonic # 28
29.0000k hz -124.7105 db at 10.1710 Deg Harmonic # 29
30.0000k hz -125.3049 db at 10.5233 Deg Harmonic # 30
THD = -28.7068 ( 36.6996m% ) SNR = 5.9991 db
SFDR = 6.0092 db at frequency 1.5000k hz
It seems u misunderstand fft analysis. The frequency bin in your sim file is 1/2m=0.5K, which is too large comparing with your signal freq 1K. Therefor u should increase signal frequency or increase sim time.
I don't clearly understand about FFT.
when I compared RECT window with HANN,the result is very different with the same other parameter.
SNR(rect)>200db
SNR(HANN)<7db
