smartsarath2003
Member level 4
lm338 short circuit breaker
How can we impove the load regulation of a power supply? By adding bypass capacitors. How do we calculate their values :?:
I have attached my circuit. I had pretty good regulation, when i didn't conncted my adjustatable current circuit. The regulation is around 20% after adding that circuit. Why does this effected. I thought Vce<0.5V(Q1) and shouldn't cause any problems. I tried to connect the resister bridge(R1 &R2 ) after Q1. Still that doesn't solve the problem
Also in the datasheet, it shows that a protection diode needed to protect from bypass caps. Will that comes to action when the output is switched off
Can any one help me with my regulation problem plz :roll:
