ray.deng
Newbie level 6
This is a two stage op amp. The first stage is a folded cascode and second stage is common source stage. I'm directly using the second stage driving the output resistance. I'm measuring the PSRR+ by connecting the output to the negative input while grounding the positive input. See the schematic.
With a singal source at the positive voltage supply, I got a PSRR+ at about 22dB at 1Mhz. However, the project spec requires 40dB at 1Mhz. What should I do to improve the PSRR+? By the way, PSRR- seems to be fine. It is about 60dB at 1Mhz. Thanks!
