How to import Orcad netlist to DXP 2004?
EDA_hg81
Advanced Member level 2
How can I realize this?
Thank you.
You cannot load an Orcad netlist into DXP2004. You first must convert the Orcad netlist into Protel or Tango format. You can do this either manually in a text editor, or by use of a software tool such as RSI Omninet.
Once you have the netlist in Protel format, you use the method described in: **broken link removed**
A better way would be to load the Orcad .DSN capture file into DXP, clean it up to make it a valid DXP schematic. Then your netlist would be produced directly from the converted schematic.
    EDA_hg81
