How to implement a SYNCHRONOUS RS232 link using microcontrollers?
doragasu
Newbie level 3
Newbie level 3
I have been asked to implement a synchronous RS232 link. I have been reading documentation (googling and reading V.24 ITU-T recommendation), and I'm a bit confused about what I have to do.
If I understood correctly:
Both TX and RX signals are synchronized using:
a) either two different clock signals (one for TX, other for RX, both sent by the DCE to the DTE). These signals change at the same time RX/TX changes;
b) Or a single clock signal sent from the DTE to the DCE. This clock signal changes when the transmitted/received bit is at half its duration.
If option b) is used, option a) cannot be used and vice versa, right? I'm a bit confused about this.
Also when using option a), I suppose this can be implemented using two SPI ports (with level shifters), right? If this is the case, and I decide to use e.g. a PIC18F97J94, what would be the difference between using two of its MSSP ports (SPI mode) and using two of its EUSART modules? Isn't the protocol exactly the same?
if you are using a PIC18F97J94 it has 4 USART modules, see section 21.0 ENHANCED UNIVERSAL SYNCHRONOUS ASYNCHRONOUS RECEIVER TRANSMITTER (EUSART) of the device data sheet
also have a look at the USART code examples
