How to implement 1us delay in Linux?
davyzhu
Advanced Member level 1
oriental
Hello all,
The Linux's timer tick resolution is 1ms, and how to implement 1us delay in Linux, by hardware or by software?
DAVY
u can set by software also. but it is risk process.
u can try by software first
If you are working on an Intel Pentium class workstation, you can use the assembler instruction "rdtsc", which enables you to read a hardware counter running at cpu clock cycle speed.
You can write a assembler routine which reads this counter and loops until it reach a value corresponding to the delay you need.
See this pdf to see how to access this counter :
h**p://www.eecg.toronto.edu/~de/RDTSCPM1.pdf
Replace * by t
