echo47
Advanced Member level 6
`ifdef modelsim
Do Verilog compilers (ModelS!m, Synpl!fy Pro, and XST) provide any predefined values that can be tested at compile-time (perhaps by using `ifdef statements) to determine which compiler is being used?
C compilers usually provide a macro such as __MSVC__ or __GNUC__ that identifies the compiler, but I can't find anything like that in Verilog compilers.
As a workaround, I could probably set a value with a command line parameter, but I'd prefer to use a predefined value provided by the compiler.
Thanks.
Thanks.
