how to hold the pwm power voltage stable?
jigdo
Junior Member level 1
The pwm power is a part of my project.Now ,I have a problem:how to hold the pwm power voltage stable? My method as a feedback control:
first: down the voltage (pwm power stabler voltage 310V)
second: use a A/D sample the low voltage,transfer the result to DSP,then
the DSP adjust the pwm's the proportion between high level and low level to make power voltage up or down.
Thank you!
I think it would be easier to use analogue
Hi;
you can use analoge way or digital one ( which you use).
I dont know what is you problem!
Rgards Amerion
