how to have the routage ISIS To ARES
milanino
Member level 2
Member level 2
hi
I would like to do the routage of this circuit with ARES.
The circuit LM1893 i have create it it's not in the proteus' library
please help me to do this routage
and for the keypad and the transformer how can i do ??
for keypad u can use sil-con pacage.
for transformer u can make your own footprint's according to dimension's.
i can use connector instead of transfomer lcd and keypad??
please for the LCD, it have 14 pins but 7 pins are linked to the pic and 7 to the ground. i use a 14 pin connector or 7 pin connector are good enough??
there is maximum 14 pin connector . but lcd have 16 pins .
so use 14 pin and 2 pin sil connector in schematic.
but when you are routing you can put these nearby one another.
Hi all,
Im neebiw in proteus.
Can you guide me how to check my isis component got connected accordingly and run properly?
