how to got whole PLL bandwidth
fencl
Member level 1
Member level 1
hi,
i'm a newer in pll, papers often told me the pll bandwidth should less than 1/10 of operation frequency. but how can i got the whole pll bandwidth with hspice? we take a basic pll for eg. vin is input ck,vref is feedback ck. and vout is output ck.
what kind of source should i set?since pll is a discrete system with no op point as opamp.
vin vin 0 dc ? ac 1
.ac dec 10 1 1g
i try like this source ,but the result seems incorrect.
Then how could i got it ?
maybe it is better to built the linear model in matlab and check the bode plot
fencl said:
hi,
vin vin 0 dc ? ac 1
.ac dec 10 1 1g
you will have to create a linear model of all the PLL components and then you can plot it in spice giving it stimulus similar to what you showed below.
fencl said:
hi,
i'm a newer in pll, papers often told me the pll bandwidth should less than 1/10 of operation frequency. ?
Who told you that? Santa Claus?
So if you have a 20 GHz oscillator and you phase lock it, your PLL bandwidth sould be 2 GHz wide????
The loop bandwidth has NOTHING to do with the VCO oscillating frequency.
Hi all,
Its true fencl, take a look here:
