How to go to Layout plus from Capture CIS ?
StoppTidigare
Full Member level 2
Full Member level 2
Northern earth
Hi, I am sorry. Yes, I should read that f***ing manual.
So maybe I should be ignored....
I am using version 14.2.
I've tried Tools->Export Netlist, but when opening up Layout plus it ask for files with another extension.
regards,
StoppTidigare
the first question you are being asked is the board template i think the file is default.tch. this file is available in your layout folder. Then it will ask you for the .mnl file which is ur netlist file.
Hope this helps you.
Hock
