asad parvez
Newbie level 6
I want to glow 30 LEDs on a single 9V battery plzz help me for this........telll if any ic can do this thing.
I dont think that you need a boost converter as this will add complexity and consume.
You need to know at what current Id you will operate your leds and the voltage drop Vf of each one. That depends on the specific leds you want to use.
For example with Vf=2v Id=10mA you can put 4 leds all in series with a resistor of 100ohms. And repeat this circuit x7 to have 28 leds. That is a combination of series and parallel circuits. The two remaining leds go in series with a resistor of 500ohm.
Take into account that in this case the total current will be 8x10mA= 80mA. The battery may not last very long. With more powerful leds the battery could be depleted in short time.
This page will do everything for you:
Hope that this helps.
