Amalinda
Banned
I have an active GSM and GPS antenna of gain 9 and 2.5 respectively.
I want to connect these to the SIM908 as I am now in the PCB designing stage in Eagle.
How do I connect these two to the SIM908? I understand that I need to connect pin 59,79 the GSM and GPS antenna pins to the respective middle pin. But then, Since both my antennas require power Can you explain as to how I can provide power?
thank you so much.
thank you so much.
