How to get time from structure
Wajiduddaim
Junior Member level 1
darbar-e-Sadria
hi
i m using esp32 and its wifi library in Arduino
After getting NTP time
when i Call this function everything fine
C++:
void printLocalTime()
  struct tm timeinfo;
  if (!getLocalTime(&timeinfo))
    Serial.println("Failed to obtain time");
    TimeSuccess = false;
    return;
  TimeSuccess = true;
  Serial.println(&timeinfo, "%A, %d %B %Y %H:%M:%S");
i want to get time separately like
LocalHour = timeinfo's Hours value
ect.
i tried some methods but they didnt work like
Localhour = timeinfo.tm_hour;
the result is 0 (Zero)
how can i get values
It depends which library you are using but your code shows nothing to load the "%A...%S" values.
Look at the structure elements in "tm" then try printing them individually, for example try:
Serial.print(timeinfo.hour);
to see if the hour value is shown. You may have to use different names, they will be defined in the library you are using.
Brian.
if
works...then what does
Serial.println(&timeinfo, "%H");
do?
Klaus
thanks for your reply
i am using TimeLib.h library and wifi library
i tried but it didnt work
if
do?
yes its work and print hour value
but i need to compare hour with another value
suppose tm_hour = timeinfo.hour
if(tm_hour == LocalHour)
or
if(tm_hour <= 12)
Maybe %H is a string or String. Arduino has some strange variable types!
If what Klaus suggested doesn't work, try "if(%H.toInt() == LocalHour)".
You can always use sprintf but at the expense of needing lots of memory.
Brian.
Looking at the code in initial post #1, I have several questions
1. I don't see struct tm defined in TimeLib.h
tm is a static struct in Time.cpp
2. where is getLocalTime() defined, what's the argument type?
3. where are the format specifiers used in "%A, %d %B %Y %H:%M:%S" defined or explained? Only %d is standard C syntax.
