amwygah
Junior Member level 1
- Joined
- Jun 4, 2010
- Messages
- 16
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,283
- Location
- chengdu,sichuan
- Activity points
- 1,400
Not quite. I'm assuming he means Vid = differential input voltage and Vic = common mode input voltage.You wrote: Vid = Vout*R1/(R1+R2)
That means: Vout/Vid=1+R2/R1.
This is nothing else than the classical formula for a non-inverting gain stage with opamp.
Still scratching my head about the rest. I've got as far as:then
Vout = [Vout*R1/(R1+R2)*0.5+Vin*R2/(R1+R2)]*Acm + Vout*R1/(R1+R2)*Adm
Respectively a CMMR test circuit.Remark: The shown circuit is the classical opamp-based differential amplifier with Vin=Vin1=Vin2.
I think, the expression is correct, except for the Adm sign, which should be inverted. Thus the for Adm >> Acm and Adm >> 2000,Vout/Vin = 2000*Acm / [2002 - Acm - 2Adm]
Approximately. The gain can be nevertheless calculated. Thats the given problem.This circuit gain is Zero.
In that case, I agree with his reasoning ...
The purpose of the cicruit is well explained by the equations in my opinion. It's a common mode rejection test circuit, the Vout/Vin gain will be non-zero for non-zero Acm values.CAn u explain what r u trying to do ?
I don't see any errors in his arithmetic.Hi godfreyl, can you please explain why you can "agree with his reasoning" ?
Yes, the other half of the truth is that the common mode input voltage, Vic = Vout*R1/(R1+R2)*0.5+Vin*R2/(R1+R2), but he took that into account as well.In words: Vid = Vout*R1/(R1+R2) is the voltage that is fed back...
But this is only one half of the truth because the circuit is NOT a simple non-inverter.
At last ,i got that
Vout/Vin is approximately equal to 1000*Acm/Adm.
Unfortunately , i was told that the answer is 2000*Acm/Adm.
Could anybody tell me why for the factor 2.
Yes, quite right. I found the mistake in my arithmetic at last.Vout/Vin = + 1000 * Acm / Adm
His problem is basically to find the CMRR by measurement, without looking at the datasheet.the cmrr is a ratio given in the data sheet....
if he knows the parameter he can simply use the formula ..i dont understand what kind of help he needs and why ?
Vout = Adm*Vid +Acm*Vic
Vid = -Vout*R1/(R1+R2)
