haribabu
Junior Member level 2
Hi all ,
I am designing LVDS transmitter . I am using a common mode feedback circuit to stabilize the output common mode voltage and I want to do the stability analysis for this feedback loop.For that I need to get the pole at the output of the LVDS driver .Should i consider the tx line model and the terminating resistor(100 ohm ) at the receiver while calculating the pole !!!!!!!!!!
