How to get the arg1, arg2 and arg3 actual values in this C code?
Help
Advanced Member level 2
Anyone can help me to explain the code?
int varfunc (char *buf, int id, ...)
   va_list tag;
   va_start (tag, id);
   if(id == 0)
      char i=0, result=0;
      int arg1;
      char *arg2;
      char arg3;
      arg1 = va_arg (tag, int);   // 27(1Bh) at int address = 0x1B00
      arg2 = va_arg (tag, char *);
      arg3 = va_arg (tag, char);
      arg1 = arg1 + 0x02; // arg1 != 0x0008???
      while(arg2[i] != '\0') // arg2[] = {0} ????
         result = arg2[i];
         i++;
      arg3 = arg3 * 0x02; // arg3 = 0 ???
   else
      char i=0, result=0; // static Variable
      char *arg1;
      char *arg2;
      char arg3;
      arg1 = va_arg (tag, char *);
      *buf = '1';
      arg1 = "01";
      arg2 = "9876";
      arg3 = 100;
      while(arg1[i] != '\0')
         result = arg1[i];
         i++;
      i=0;
         result = arg2[i];
         i++;
      arg3 = arg3 * 0x02; // arg3 != 0x06 ????
void caller (void)
   char tmp_buffer [10];
   varfunc (tmp_buffer, 0, 4, "Test Code", 2);
   varfunc (tmp_buffer, 1, "Test", "Code", 3);
Why i can't get arg1, arg2, and arg3 actual value?
How can i get the actual value?
Thank You.
stdarg while va_arg code forum
Try enabling all of your compiler's warning messages and recompile. The messages will help your debugging.
The biggest troubles I see are missing header file, mismatched type of arg3, and missing va_end.
This works for me in MinGW gcc 3.4.2:
#include <stdio.h>
#include <stdarg.h>
int varfunc(char *buf, int id, ...)
   va_list tag;
   va_start(tag, id);
   if (id == 0)
      int arg1;
      char *arg2;
      char arg3;
      arg3 = va_arg (tag, int);
      printf("id == 0: %d %s %d\n", arg1, arg2, arg3);
   else
      char *arg1;
      char *arg2;
      char arg3;
      printf("id != 0: %s %s %d\n", arg1, arg2, arg3);
   va_end(tag);
   return 0;
int main (void)
   return 0;
Output:
id == 0: 4 Test Code 2
id != 0: Test Code 3
More info in the comp.lang.c FAQ (this FAQ is full of wonderful advice):
http://c-faq.com/varargs/varargs1.html
c variadic function implementation without stdarg
Can i simulate the result by this way... for arg1 = arg1 + 2; i just wanna to see the result but if i do that i can't get the result arg1 = 6. I think the following arg2 and arg3 also the same problem. Why?
and why the arg3 type is 'int'?
I am using Keil compiler but i think is the same...because it it general code, am i right?
Thank You.
stdarg c
'char' is promoted to 'int' when passed through '...', so your varfunc() function must expect an 'int'. One mismatched argument could corrupt all of them.
I don't understand your sentence about simulate.
If Keil is ANSI C compliant (I don't know if it is), then it should behave according to standard C language.
c language printf stdarg
You mean the last declaration must declare as int in va_arg (tag, int); if the arg3 type is char?
      char arg3;
let say if the arg3 type is int, so the va_arg (tag, long); , am i right?
Can i use this 3 variable (arg1, arg2, and arg3) to do something else (ex. arg3 += 2; )? or It's just for printf purpose? Can you make some examples?
Thank You.
stdarg in c
Yes, if your calling function passes a 'char' in arg3, it gets promoted to 'int', so you must specify 'int' inside your va_arg().
No, if your calling function passes and 'int' in arg3, it remains an 'int'. It does not get promoted to 'long'.
Yes, you can use the three arguments just like ordinary function arguments. I used printf simply because I wanted the program to output visible results.
Please refer to a good C book that describes how to use variable number of arguments. You may also find some answer in the comp.lang.c FAQ. In particular, this one:
http://c-faq.com/varargs/float.html
