[SOLVED] how to get the ac 100 v supply in proteus?
tauseefrehman
Junior Member level 1
how you got the ac supply of 100 v in proteus, because i can't getting it.plz help me........
hi
just click on "P" ithink you know which one "P"
i mean Parts caling P and then type in writing window (alternator)
appair the alternator then you set frq and volts
if you donot under stand please tell me i will explain with screen shot
T/C
bye
One way is to use an AC voltage source, this is referenced to ground, just set the properties to the value you want (frequency, amplitude)
The second way is as qayyoum mentioned an alternator.
In this case you have full control of the reference point because the two ends are floating.
Alex
