YuriyP
Newbie
Hi All,
I'm trying to write a small script which will change the lumped port impedance leaving all other parameters unchanged.
I have found the "EditLumpedPort" but it needs ALL parameters to be set as a Structured array...
I have many ports with different integration lines, is it possible to get the info about integration line before the Port editing to use this in "EditLumpedPort" command? in this way the integration line stays unchanged..
of corse the best way would be to change only Impedance without touching all other parameters...
thanks in advance
thanks in advance
