KMS17
Newbie
![Newbie level 2](/styles/images/ranks/alevel2.gif)
C:
#include<reg51.h>
#include<string.h>
#include<math.h>
//Pin description
P1.4 is RS
P1.6 is E
P2.4 to P2.7 are keypad row outputs
P2.0 to P2.3 & P1.0 to P1.1 are keypad column inputs
extern void lcd_init(void);
extern void lcd_cmd(unsigned char);
extern void lcd_char(unsigned char);
extern void lcd_str(unsigned char *);
extern void store_font_cgram(void);
extern void lcd_display(unsigned char);
extern void delay_ms(unsigned int);
void delay_ms(unsigned int i)
unsigned int j,k;
for(;i>0;i--)
for(j=122;j>0;j--);
for(k=122;k>0;k--);
sbit rs=P1^4;
sbit rw=P1^5;
sbit en=P1^6;
void lcd_init()
lcd_cmd(0x30);
delay_ms(10);
lcd_cmd(0x30);
delay_ms(10);
lcd_cmd(0x30);
delay_ms(5);
lcd_cmd(0x38);
lcd_cmd(0x10);
lcd_cmd(0x01);
lcd_cmd(0x0c);
lcd_cmd(0x06);
lcd_cmd(0x0f);
void lcd_display(unsigned char ch)
P3=ch;
rw=0;
en=1;
delay_ms(2);
en=0;
void lcd_cmd(unsigned char ch)
rs=0;
lcd_display(ch);
void lcd_char(unsigned char ch)
rs=1;
lcd_display(ch);
void lcd_str(unsigned char *ch)
while(*ch)
lcd_char(*ch++);
void delay (unsigned int i)
unsigned int j;
for(;i>0;i--)
for(j=122;j>0;j--);
sbit R1=P2^4;
sbit R2=P2^5;
sbit R3=P2^6;
sbit R4=P2^7;
sbit C1=P2^0;
sbit C2=P2^1;
sbit C3=P2^2;
sbit C4=P2^3;
sbit C5=P1^0;
sbit C6=P1^1;
char keypad[4][6]={'o','7','8','9','x','/','p','4','5','6','-','c','%','1','2','3','b','y','r','0','.','=','+','z'};
void row_finder(int col) //Function for finding the row for column 1
R1=R2=R3=R4=1;
C1=C2=C3=C4=C5=C6=0;
if(R1==0)
lcd_char(keypad[0][col]);
if(R2==0)
lcd_char(keypad[1][col]);
if(R3==0)
lcd_char(keypad[2][col]);
if(R4==0)
lcd_char(keypad[3][col]);
void main()
lcd_init();
lcd_cmd(0x80);
while(1)
C1=C2=C3=C4=C5=C6=1;
R1=R2=R3=R4=0;
if(C1==0)
row_finder(0);
delay(500);
else if(C2==0)
row_finder(1);
delay(500);
else if(C3==0)
row_finder(2);
delay(500);
else if(C4==0)
row_finder(3);
delay(500);
else if(C5==0)
row_finder(4);
delay(500);
else if(C6==0)
row_finder(5);
delay(500);
My doubt here is from the Row finder operation how can i get the values and place it in a switch command to make it work as a calculator?
