how to get 6v from 12v car battery
kobre98
Full Member level 2
Full Member level 2
Gaza, Palestine
Hi guys
I have 12v car battery with 150 Ampere
I want to make a circuit that allow me to get 6v from it since I need these 6v to turn some devices.
It would be okay if anyone gave me a circuit that transform from 12 volt to any other rating voltage including 6v
I want a circuit or something like that.
your help is appreciated
use LM317...
If your device is more power consuming or you need more efficiency means you can go for switched regulators....
How much ampere I can get from the LM317 ?!
and what is the switched regulators that you talked about could you give me a more detailed answer ?!
1.5A with proper heat sinks.... switched regulators are a circuits which used to regulate the voltage without making power loss,
example Mosfet IGBT chopper circuits they also can be used as regulator with pwm technique...
Hi guys
Hi kobre98
It depends on how much current do you require and what is the required ripple voltage ?
Anyway , i suggest you LM2576 which is one of the simplest witching regulators around the world ! and of course with efficiency more than LM317 !
Best Wishes
Goldsmith
