How to generate the 30s delay, traffic light, vhdl code
alle
Newbie level 2
Newbie level 2
Singapore
Any ways that I can generate a 30s delay for my traffic light vhdl code? the red light will stay for 30s, yellow light for 2s. How to generate these delay? Pls help.
How to generate delay?
DESIGN A COUNTER AND BE CAREFUL WITH YOU SYSTEM CLOCK FOR EXAMPLE YOU HAVE A CLOCK FO 40M ,25ns FOR ONE CYCLE.YOU WILL DESIGN A COUNTER OF (30S+2S)/25NS
IT ISN'T VERY DIFFICULT,IS IT?
Re: How to generate delay?
perhaps not for you but it is for me.. since im just starting to adapt to vhdl couple of days ago.. thats why i need some directions
Use Wait statements with time.
example is :
Wait for 100ns;
where ns is for nano-sec. you can mili-sec (ms) or only sec (s)
Wait statements are not synthesizable.
You need counters when the proposed code must be synthesizable.
Devas
you need a set of counter to implement the timers...
First up all u need to find the 1micro-second tick..the generation of this depends on the clock operating frequency of your circuit..for example if u r operation @ 200Mhz.. then u need to design a counter to increment for every clock and once the counter reaches 200.. a pulse is generated, which indicates 1micro-second tick..use this tick to generate millisecond.. and the millisecond count to sec counter and second count tick to generate the required timers...
