trashbox
Hi all,
#1.
I need to add a negative voltage on the PCB for my test chip, the average output current is about 100mA through this voltage. Except the charge pump chip, how can I realize a negative voltage with simple method on PCB?
#2.
I also need a big size mosfet (power transistor?) with source follower connection for my test chip's power supply. It means this nmos source is connected with my test chip's power, drain is connected with PCB power. How can I find such a mosfet?
Thanks in advance!
#1.
#2.
Thanks in advance!
