Light a match. That will generate infrared that travels more than 100m. Or you can use a candle or a light bulb or a soldering iron.I want to generate infra red radiation which is able to travel a distance of 100 m near about
That should be quite easy but I would use a red laser diode or laser pointer so I can see where it's shining.(say i want to send an audio signal via infra red radiation or want to operate a switch)
haha ok ok but tell me is it possible for a photo diode at 100m distance to sence the radiations from a candle etc etc ?
im talkin in terms of electronics (say i want to send an audio signal via infra red radiation or want to operate a switch)
Sounds like you want to suggest that "IR rays" and photons are a different thing. But electromagnetical wave and photon are manifestations of the same physical phenomenon.Photo diodes sense the incidence ot photons rather than IR rays so there may be some error in using this here
some time back we discussed here and I found thermopile are more suitable for sensing IR rays
