how to generate full wave rectified sine in hspice
lhlblue
Member level 3
Member level 3
i want to get a full-wave rectified sine wave in hspice, what input source should i use?
i have tried some way, but not work.
can you explain your problem with more details?
Put a sine wave through a bridge rectifier. If you use a high voltage source the error due to diodes will be small. Scale the signal with a voltage controlled voltage source.
Keith
