How to generate clock of frequency 120Khz??
xpress_embedo
India
I am using ICL7135 to make a Voltmeter,
In that i have to provide a clock input to that, so how can i do so, using OP-AMP or by some other simple simple components.
I have to generate clock of 120Khz Frequency, please help me
No i dont need an accurate clock.
Is der any circuit usibg simplr components likr op amp transistor capacitor through which i can generate clock of frequency 120khz
pls help i cant use any other ic's for that purpose, pls suggest me something.
a 555 timer can also do the job i think 120k can be generated through it.. if it can nothing else would be more easier & cheaper
I have used the 74HC04 version
Using a 4093 you can make a simple oscillator.
How about using a simple 8 pin pic? Perhaps a 12F629/675?
You'd get your 120khz with zero other components, besides the pic itself!
Regards.
