what do you want to know about it???? be a little more specific. do you want Verilog or VHDL codes or do you want an implementation with a microcontroller like PIC.
a simple search on edaboard and google will give you alot of info
What do u want to implement a psuedo random sequence generator in RTL ( u can find a example of that HDL chip design - smith book) or a random sequnce for RTL verification
Search for Linear Feedback Shift Register (or LFSR)on google. This structure is basically a circular shift register with XOR gates between some of the stages, it produces a pseudo-random sequence when clocked...
hi,
you can go through a chapter on random number generation in a book by populis "Probability, Random Variables, and Stochastic Processes".You can find c code for random number generation in "numerical recipes in c" it is available online.If u r interested in mcu implementation of it check this application note by ti https://focus.ti.com/docs/apps/catalog/resources/appnoteabstract.jhtml?abstractName=swra041
it is concerned with frequency hopping but you can also find code for random number generation.
pimr
I want a psuedoe random sequence generate to add to my answer in order to spread the error.
It may be used in digital signal processor or asic...
Thanks for the above discussion I will check in the "numerical recipies in C".
you can use LFSR (Linear Feedback Shift register) method....it most reliable and have capability to generate any kind of patterns.....
you may also want to learn about CRC (Cyclic Redundancy check)...this will help you solve...how you can make use of LFSR.....for detecting the errors...
Most of lfsr approach can't generate psuedo random sequence with
zero number.
Doesn anyone know how to generate psuedo random sequence with zero number?
