It is generated by extraction tools like STAR-RCXT from place-n-route database of a fully laid out and routed design.
It can also be generated without layout/routing by syntheisis tools using placement aware methodology ( like DC - topographical). But those are just first cut estimates and would be off from actual parasitics that you'll get in layout.
Can it be generated using primetime using the commands:
write_parasitics -format SPEF filename.spef ? such that it writes all parasitics
annotated on the current design to the file specified
in the filename argument.
