How to generate a hex file in Keil C51?
zohaib
Member level 4
Member level 4
PAKISTAN
does keil c51 make .hex file ?
if or if not how can i generate?
thanx
keil c51
yes keil can do.....
but if you have the ASM file you can use alot of small and easy tools(if you whant I can upload one of theme)
and you cand compile your file whith proteus too(some one dont know this!)
    zohaib
Re: keil c51
At menu bar :
FILE -> PROJECT -> OPTIONS -> CREATE HEX FILE
    zohaib
Re: keil c51
On meny bar:
select Project -> Options for target -> Output -> Create hex file
Regards,
Mr.Cube
    zohaib
Re: keil c51
see the attachment.
