How to generate a dynamic frequency square waveform in HSPIE
huanchou
Member level 2
Member level 2
Dear all:
I would like to generate a square waveform with the ferquency changed from 99M to 100M among 15us in HSPICE environment.
But I have try many methods, I still can't generate the waveform.
:cry:
Any one have the idea to generate the waveform?
Re: How to generate a dynamic frequency square waveform in H
Maybe you can try to design a VCO on your clock signal input, then change the
control voltage (Use the pwl function), the clock output frequency will be changed.
You also can try to design a VCO behavior model to speed up your simulation.
    huanchou
Yes, it work. Thanks for your help.
I use the VCO to generate the pattern. It work very well.
You may use PWL or E element (with VOL=) to generate the waveform.
    huanchou
