How to generate a digitized sinusoidal input signal for DAC?
samvelc
Member level 1
Member level 1
Armenia
Hi all,
I have designed a DAC. Now I want to test it.
I want to apply a digitized sinusoidal signal as a input.
But I do not know how to generate such kind of input signal.
Could you please advice.
Do you have a such example.
Thanks in advance.
Re: Input signal for DAC
Find several methods described!
Thanks,
But I need a digitized sinusoidal input signal.
In the verilog-a code, instead of using count=count+1, use
count=floor(512*sin(2*M_PI*f*n*tp))+512;
for a 10-bit DAC.
You also need to remove
if(count==4096)
count=0;
...and add
n=n+1;
I might have forgotten some little details, but I'm sure you'll figure them out!
for a 10-bit DAC.
if(count==4096)
count=0;
...and add
n=n+1;
Thanks,
I will try it.
hi friend
can you explain how to convert digital sinoidal input signal to analog in verilog.
actually i need to implement verilog code to convert sin 2pi analog signal into digital (ADC).
i can get an idea with your code.
actually i need to submit this assignment by end of this week.
please help me.
