sai685
Junior Member level 2
I have a code of testbench for fifo in the below. please tell me how to generate a checker \
- wr_full is asserted when the fifo has 32 element.
- rd_empty is asserted when the fifo has 0 element.
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 module fifo_top_tb; reg wr_clk,rd_clk; reg[31:0] data_in; wire[31:0] data_out; wire rd_empty,wr_full; reg reset_w; reg reset_r; reg write_enable,read_enable; reg rptr,wptr; bit [:0] que [$]; fifo_top top1(.wdata(data_in), .rdata(data_out), .wclk(wr_clk), .rclk(rd_clk), .wreset_b(reset_w), .rreset_b(reset_r), .write(write_enable), .read(read_enable), .rempty(rd_empty), .wfull(wr_full)); task reset; write_enable =0; read_enable =0; wr_clk=0; rd_clk=0; data_in=0; reset_w=0; reset_r=0; // asserted endtask task write; //TODO: random, value (input ); @(posedge wr_clk) begin data_in =$random; write_enable=1; if(!wr_full) begin que.push_back(data_in); $display ("%t - queue write data = %d", $time, data_in); $display("que.size=%d",que.size); end end endtask always #5 wr_clk= ~wr_clk; always @(posedge wr_clk or posedge rd_clk) begin if(que.size==1) begin $display("empty"); end else if(que.size==32) begin $display("full"); end end task read; //TODO: random, value ; @(posedge rd_clk) begin read_enable=1; if(!rd_empty) begin que.pop_front(); $display (" queue data = %d", que.pop_front() ); $display("que.size=%d",que.size); end end endtask always #5 rd_clk=~rd_clk; initial begin reset; #20 reset_w =~reset_w; #20 reset_r =~reset_r; repeat(32)write; fork read; write; join end //C H E C K E R initial fork assert (wr_full==que[32]) else $error("it is wrong"); assert (rd_empty==que[0]) else $error("it is wrong"); join initial $monitor("wr_clk=%d,reset_w=%d,reset_r=%d,write_enable=%d,read_enable=%d,data_in=%d,data_out=%d,wr_full=%d,rd_empty=%d",wr_clk,reset_w,reset_r,write_enable,read_enable,data_in,data_out,wr_full,rd_empty); initial #1200 $finish; initial begin $dumpfile("fifo_top_tb.vcd"); $dumpvars(wr_clk,reset_w,reset_r,write_enable,read_enable,data_in,data_out,wr_full,rd_empty); end endmodule
