How to generate 4 bias voltage?
What's the meaning of "4 bias voltages"? Do you mean four independent voltages? if it is, you can just use regulator or bandgap.
hi,
I want to design a circuit which can generate four diffenrent voltage,for example V1,V2,V3,V4.
Do you have any paper about this?
Thanks.
Hi holddreams,
Are these bias voltages used as reference in your system, if yes. Then buffer the BGR output and source a current through a resistor ladder, get your references.
If no, then please elaborate on what are they used for, what accuracy do you need in them?
ambreesh said:
Hi holddreams,
quote]
yes, i want it that way.
Can you send me a paper about this?
Or can you draw a configure as you said?
Thanks.
Also another question, if use a resistor ladder,does the temperature have a little effect on the whole circuit?
I think Martins book is having a ckt which shows the cascode bias volatge generations and tail curent bias generationjs voltages
Use BGR to generate a stable voltage. Convert it to current. then use current mirrors to get any proportional current you need....
The paper provided is not a good example. There is no start-up circuit, and the schematic is wrong. (NMOS and PMOS symbols incorrect). I wouldn't trust it...
you can get a Vref about 1.2V with a bandgap reference,then using the amplifier you can get more voltage which are steady as the Vref
you can get the different voltages:
vout=(R1+R2)/R2*Va≈(R1+R2)/R2*Vin
Dear friend,
You can use one independent current source, and make your required voltages using current mirrors. Good Luck
I guess these 4 bias voltages are for opamp bias, using replica method, you can get them without consider voltage.
